Introducción
This guide shows you how to replace the lithium-ion-battery of your Mate 10 lite.
You have to take appropriate security measures if the battery is swollen. For your own security you should drain the battery to 25% as that reduces the risk of fire if you damage the battery during repair.
The backcover is not glued so it can be opened easily.
Qué necesitas
Remove the SIM card by using a paperclip or a special tool and inserting it into the hole next to the SIM card tray until it pops out.
Remove the Torx T2 screws on the bottom of the case(next to the USB port)
Use the Opening tool on the bottom of the case and pry it open
go around the side to open the phone
place the device screen down and take the backcover off to the left side
Red: Phillips #00 screws
Blue: Remove the cable clamps with the Spudger
Remove the cables connecting to the backside and remove the cables that run over the battery
Insert the plastic card into the side and push them under the battery
the glue under the battery can be removed with highgrade IPA or a special glue remover. Otherwise you can pry the battery out with the spudger, the plastic cards and the opening picks
Follow the guide in the opposite direction and use the replacement battery.
2 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Un comentario
Achtung: Ich habe irrtümlich das Display "zerlegt", weil der aufgeblähte Akku hier einen Spalt gemacht hat, in den ich leider das Tool angesetzt habe... :/
