Saltar al contenido principal
Huawei Honor 5X Volume and Power Buttons Replacement
Qué necesitas
  1. Huawei Honor 5X Volume and Power Buttons Replacement, HUAWEI HONOR 5X Disassembly: paso 1, imagen 1 de 1
    • Turn off your cell phone before disassembling.
  2. Huawei Honor 5X Volume and Power Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. Huawei Honor 5X Volume and Power Buttons Replacement: paso 3, imagen 1 de 2 Huawei Honor 5X Volume and Power Buttons Replacement: paso 3, imagen 2 de 2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. Huawei Honor 5X Volume and Power Buttons Replacement: paso 4, imagen 1 de 1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. Huawei Honor 5X Volume and Power Buttons Replacement: paso 5, imagen 1 de 2 Huawei Honor 5X Volume and Power Buttons Replacement: paso 5, imagen 2 de 2
    • Pry off the back with a plastic opening tool.
  6. Huawei Honor 5X Volume and Power Buttons Replacement, Battery: paso 6, imagen 1 de 1
    • Remove the pink sticker.
  7. Huawei Honor 5X Volume and Power Buttons Replacement: paso 7, imagen 1 de 1
    • Remove the three 1.5mm Phillips #000 screws.
  8. Huawei Honor 5X Volume and Power Buttons Replacement: paso 8, imagen 1 de 2 Huawei Honor 5X Volume and Power Buttons Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  9. Huawei Honor 5X Volume and Power Buttons Replacement: paso 9, imagen 1 de 1
    • Remove the battery from the phone.
  10. Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: paso 10, imagen 1 de 2 Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: paso 10, imagen 2 de 2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  11. Huawei Honor 5X Volume and Power Buttons Replacement: paso 11, imagen 1 de 2 Huawei Honor 5X Volume and Power Buttons Replacement: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  12. Huawei Honor 5X Volume and Power Buttons Replacement: paso 12, imagen 1 de 3 Huawei Honor 5X Volume and Power Buttons Replacement: paso 12, imagen 2 de 3 Huawei Honor 5X Volume and Power Buttons Replacement: paso 12, imagen 3 de 3
    • Remove the motherboard.
  13. Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: paso 13, imagen 1 de 2 Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: paso 13, imagen 2 de 2
    Comprar
    • Use the tweezers to pull the button assembly from the small black clips on the back plate of the phone.
Conclusión
Eric Petrous
Miembro Desde 09/03/19
145 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G4, Hovde Fall 2019 Miembro de IUPUI, Team S1-G4, Hovde Fall 2019
IUPUI-HOVDE-F19S1G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 919
