Saltar al contenido principal
How to open up a Nokia N9
Qué necesitas
  1. How to open up a Nokia N9, remove top parts: paso 1, imagen 1 de 3 How to open up a Nokia N9, remove top parts: paso 1, imagen 2 de 3 How to open up a Nokia N9, remove top parts: paso 1, imagen 3 de 3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. How to open up a Nokia N9, loosen the screen: paso 2, imagen 1 de 3 How to open up a Nokia N9, loosen the screen: paso 2, imagen 2 de 3 How to open up a Nokia N9, loosen the screen: paso 2, imagen 3 de 3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. How to open up a Nokia N9, disconnect screen from phone: paso 3, imagen 1 de 3 How to open up a Nokia N9, disconnect screen from phone: paso 3, imagen 2 de 3 How to open up a Nokia N9, disconnect screen from phone: paso 3, imagen 3 de 3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
Conclusión
Una persona más ha completado esta guía.
knipwim
Miembro Desde 09/01/18
11,398 Reputación
36 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 57
Todo El Tiempo: 1,960
