Saltar al contenido principal
How to fix an unthreaded drawstring
Qué necesitas
  1. How to fix an unthreaded drawstring, How to fix an unthreaded drawstring: paso 1, imagen 1 de 3 How to fix an unthreaded drawstring, How to fix an unthreaded drawstring: paso 1, imagen 2 de 3 How to fix an unthreaded drawstring, How to fix an unthreaded drawstring: paso 1, imagen 3 de 3
    • Take the loose end of the drawstring, and cut any frayed material.
    • Take the cotter pin and thread the drawstring through the spilt end of the cotter pin.
    • Slide the drawstring to the eye of the cotter pin.
  2. How to fix an unthreaded drawstring: paso 2, imagen 1 de 3 How to fix an unthreaded drawstring: paso 2, imagen 2 de 3 How to fix an unthreaded drawstring: paso 2, imagen 3 de 3
    • Feed the cotter pin through the drawstring casing.
    • The casing will vary on each garment. In this case the drawstring casing is visible on the exterior of the garment, but it may be on the inside of your garment.
  3. How to fix an unthreaded drawstring: paso 3, imagen 1 de 2 How to fix an unthreaded drawstring: paso 3, imagen 2 de 2
    • Scrunch the drawstring casing over the cotter pin and pull the cotter pin through the casing.
    • Continue scrunching and sliding the cotter pin through the casing.
    • This takes a bit of finesse; just stick with it.
  4. How to fix an unthreaded drawstring: paso 4, imagen 1 de 2 How to fix an unthreaded drawstring: paso 4, imagen 2 de 2
    • Pull the cotter pin out through the end of the drawstring casing.
    • Pull the drawstring through, until the loose end of the drawstring comes out.
  5. How to fix an unthreaded drawstring: paso 5, imagen 1 de 3 How to fix an unthreaded drawstring: paso 5, imagen 2 de 3 How to fix an unthreaded drawstring: paso 5, imagen 3 de 3
    • Insert the cotter pin—still holding the drawstring—into the drawstring hold.
    • In this case, the drawstring hold is a small hole in the garment. The drawstring hold is just the place where the drawstring will be sewn to the garment. This may vary from garment to garment.
    • Pinch the drawstring inside of the drawstring hold.
    • While holding the drawstring, pull the cotter pin out, sliding the drawstring out through the spilt in the pin.
  6. How to fix an unthreaded drawstring: paso 6, imagen 1 de 2 How to fix an unthreaded drawstring: paso 6, imagen 2 de 2
    • While holding the drawstring in the hold, mark where the drawstring will be sewn with tailor's chalk.
    • If you aren't sure where to sew the drawstring, feel for the other end of the drawstring. In most garments, the drawcord is symmetrical.
    • Sew several passes along the chalk line, being sure to catch the drawstring.
Linea de Meta
2 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
88,580 Reputación
132 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
136 Miembros
15,116 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 103
Ultimos 30 días: 387
Todo El Tiempo: 26,589
