Saltar al contenido principal
How to Wash and Dry a Waterproof Jacket
  1. How to Wash and Dry a Waterproof Jacket, How to Wash and Dry a Waterproof Jacket: paso 1, imagen 1 de 2 How to Wash and Dry a Waterproof Jacket, How to Wash and Dry a Waterproof Jacket: paso 1, imagen 2 de 2
    • Brush off any loose dirt or debris.
    • Particularly dirty spots should be pretreated. Make a soapy mixture with water and the detergent you intend to use and scrub the soiled area with a soft brush or sponge.
    • If you've got a particularly stubborn stain, check out Patagonia's Product Care guide.
  2. How to Wash and Dry a Waterproof Jacket: paso 2, imagen 1 de 3 How to Wash and Dry a Waterproof Jacket: paso 2, imagen 2 de 3 How to Wash and Dry a Waterproof Jacket: paso 2, imagen 3 de 3
    • Close the main zipper of the jacket to help prevent damage to the zipper while laundering
  3. How to Wash and Dry a Waterproof Jacket: paso 3, imagen 1 de 3 How to Wash and Dry a Waterproof Jacket: paso 3, imagen 2 de 3 How to Wash and Dry a Waterproof Jacket: paso 3, imagen 3 de 3
    • Loosen all hood and hem draw cords and loosen cuff tabs
    • Open the zippers of all pocket bags to allow soap and water to access the often-dirty pocket bags
    • Check for and remove any leftover items in the pockets
  4. How to Wash and Dry a Waterproof Jacket: paso 4, imagen 1 de 2 How to Wash and Dry a Waterproof Jacket: paso 4, imagen 2 de 2
    • Place the jacket in the washing machine and add the detergent
    • There are two types of recommended detergents:
    • Detergents designed specifically for the washing of technical outdoor gear that can be purchased at most outdoor gear stores
    • Water-based (not oil-based), biodegradable liquid detergent free of dye, whiteners, brighteners, or fragrance. Many of these detergents are marketed as " for sensitive skin"
    • More than one technical garment can be washed at once, but do not exceed more than half of the size of the washing machine drum
    • Only use the bare minimum amount of detergent needed. Excess detergent clogs the pores of the waterproof membrane and interferes with DWR function
  5. How to Wash and Dry a Waterproof Jacket: paso 5, imagen 1 de 3 How to Wash and Dry a Waterproof Jacket: paso 5, imagen 2 de 3 How to Wash and Dry a Waterproof Jacket: paso 5, imagen 3 de 3
    • Set the load size according to the relative number of garments
    • Set the water temperature to Warm or Cold
    • Run the washer on a regular or permanent press cycle setting
    • If possible, set an extra rinse cycle
  6. How to Wash and Dry a Waterproof Jacket: paso 6, imagen 1 de 2 How to Wash and Dry a Waterproof Jacket: paso 6, imagen 2 de 2
    • Run a separate rinse cycle if the machine did not have the option in the last step
    • Take the garment out of the washing machine
    • Hang to air dry if you have the time
  7. How to Wash and Dry a Waterproof Jacket: paso 7, imagen 1 de 1
    • Place the garment into the dryer either wet or after having air-dried
    • This tumble dry step is crucial as the heat resets he DWR coating that allows water to bead off the surface of the fabric
  8. How to Wash and Dry a Waterproof Jacket: paso 8, imagen 1 de 2 How to Wash and Dry a Waterproof Jacket: paso 8, imagen 2 de 2
    • Set the dryer to at least 20 minutes of Tumble Dry low.
    • A garment that goes in soaking wet may take more than 20 minutes to dry
    • The heat of the dryer is crucial to resetting the DWR coating
Linea de Meta
5 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
9 comentarios
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
Albert Daniel - Contestar
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Rachel - Contestar
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
Sarah Geers - Contestar
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
choffman - Contestar
They absolutely will replace it or give you store credit.
Nathan Keirn -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 73
Ultimos 30 días: 319
Todo El Tiempo: 53,498
