Saltar al contenido principal
How to Wash a Waterproof Jacket
  1. How to Wash a Waterproof Jacket, How to Wash a Waterproof Jacket: paso 1, imagen 1 de 2 How to Wash a Waterproof Jacket, How to Wash a Waterproof Jacket: paso 1, imagen 2 de 2
    • Inspect the damage.
    • Brush off any loose dirt or debris.
    • If you've got a particularly stubborn stain, check out Patagonia's Product Care guide.
  2. How to Wash a Waterproof Jacket: paso 2, imagen 1 de 3 How to Wash a Waterproof Jacket: paso 2, imagen 2 de 3 How to Wash a Waterproof Jacket: paso 2, imagen 3 de 3
    • Zip the main zipper of the jacket all the way up.
  3. How to Wash a Waterproof Jacket: paso 3, imagen 1 de 3 How to Wash a Waterproof Jacket: paso 3, imagen 2 de 3 How to Wash a Waterproof Jacket: paso 3, imagen 3 de 3
    • Loosen any drawstrings and undo any cuffs.
    • Unzip the pocket zippers.
    • Now is a good time to pull any hidden treasures out of your pockets.
  4. How to Wash a Waterproof Jacket: paso 4, imagen 1 de 2 How to Wash a Waterproof Jacket: paso 4, imagen 2 de 2
    • Place your jacket in the washing machine.
    • Add laundry soap.
    • You can use soap specifically formulated to clean waterproof clothing or gentle nondetergent laundry soap.
    • Do not use soap containing bleach, fabric softeners, enzymes, stain removers, perfumes or whiteners.
  5. How to Wash a Waterproof Jacket: paso 5, imagen 1 de 3 How to Wash a Waterproof Jacket: paso 5, imagen 2 de 3 How to Wash a Waterproof Jacket: paso 5, imagen 3 de 3
    • Set the load size to small.
    • Set the water temperature to warm/cold.
    • Run the washer on a regular or permanent press cycle setting.
  6. How to Wash a Waterproof Jacket: paso 6, imagen 1 de 2 How to Wash a Waterproof Jacket: paso 6, imagen 2 de 2
    • Once the cycle is completed, run the washer again on the rinse cycle to flush any remaining soap out of the jacket.
    • Take your jacket out of the washer.
    • Inspect your jacket.
    • If it looks clean and residue-free, go ahead and follow our guide to dry your jacket.
    • If your jacket looks or feels funny, place it back in the washer and run another rinse cycle.
Linea de Meta
4 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
8 comentarios
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
Albert Daniel - Contestar
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Rachel - Contestar
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
Sarah Geers - Contestar
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
choffman - Contestar
They absolutely will replace it or give you store credit.
Nathan Keirn -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 105
Ultimos 30 días: 364
Todo El Tiempo: 49,968
