Saltar al contenido principal
TI-Nspire CX Battery Replacement
Qué necesitas
  1. TI-Nspire CX Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: paso 2, imagen 1 de 2 TI-Nspire CX Battery Replacement: paso 2, imagen 2 de 2
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: paso 3, imagen 1 de 3 TI-Nspire CX Battery Replacement: paso 3, imagen 2 de 3 TI-Nspire CX Battery Replacement: paso 3, imagen 3 de 3
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: paso 4, imagen 1 de 1
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: paso 5, imagen 1 de 1
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: paso 6, imagen 1 de 1
    • Replace the back plate and the 2 screws.
Conclusión
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
9 personas más completaron esta guía.
Jim Kerman
Miembro Desde 02/24/15
314 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-2, Green Winter 2015 Miembro de Cal Poly, Team 24-2, Green Winter 2015
CPSU-GREEN-W15S24G2
4 Miembros
4 Guías creadas
2 comentarios
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - Contestar
Hola Amigo. Pudiste solucionar?
Armando02 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 38
Ultimos 30 días: 116
Todo El Tiempo: 16,347
