Saltar al contenido principal
How to Install and Remove Tiles
Qué necesitas
  1. How to Install and Remove Tiles, Remove the Front Panel: paso 1, imagen 1 de 3 How to Install and Remove Tiles, Remove the Front Panel: paso 1, imagen 2 de 3 How to Install and Remove Tiles, Remove the Front Panel: paso 1, imagen 3 de 3
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  2. How to Install and Remove Tiles, Remove the Tiles: paso 2, imagen 1 de 3 How to Install and Remove Tiles, Remove the Tiles: paso 2, imagen 2 de 3 How to Install and Remove Tiles, Remove the Tiles: paso 2, imagen 3 de 3
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
  3. How to Install and Remove Tiles: paso 3, imagen 1 de 3 How to Install and Remove Tiles: paso 3, imagen 2 de 3 How to Install and Remove Tiles: paso 3, imagen 3 de 3
    • Repeat this procedure for the remaining tiles.
  4. How to Install and Remove Tiles, Install the Tiles: paso 4, imagen 1 de 3 How to Install and Remove Tiles, Install the Tiles: paso 4, imagen 2 de 3 How to Install and Remove Tiles, Install the Tiles: paso 4, imagen 3 de 3
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
  5. How to Install and Remove Tiles: paso 5, imagen 1 de 3 How to Install and Remove Tiles: paso 5, imagen 2 de 3 How to Install and Remove Tiles: paso 5, imagen 3 de 3
    • Install the remaining Tiles.
  6. How to Install and Remove Tiles: paso 6, imagen 1 de 3 How to Install and Remove Tiles: paso 6, imagen 2 de 3 How to Install and Remove Tiles: paso 6, imagen 3 de 3
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
Conclusión
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
212,530 Reputación
1,040 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 177
