Introducción
This guide shows how to install and remove the Side Panels for your Framework Desktop.
There are two Side Panels on the Framework Desktop: the Right Panel and the Left Panel.
The Right Panel only comes in the Black version, but the Left Panel comes in either the Black or Translucent version.
Qué necesitas
Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
Remove the Handle.
Use your finger to lift up the two D-rings on the Top Panel screws.
Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
Lift the Top Panel off the chassis and remove it.
Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
Remove the Left Panel.
Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
Remove the Right Panel.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
Push the Right Panel towards the base of the computer to engage the clips.
Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
Push the Left Panel towards the base of the computer to close the gap and engage the clips.
Orient the Top Panel so its arrow is pointing towards the rear of the computer.
While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
Lay the Top Panel flat on the chassis to align the remaining clips.
Place the Handle over the Top Panel screw holes.
While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
Insert the top panel screw into its hole and twist clockwise until it feels snug.
If you need help, contact Framework support.
