Saltar al contenido principal
How to Fix a Stuck Button in Sharp Calculator
Qué necesitas
  1. How to Fix a Stuck Button in Sharp Calculator, Button Keys: paso 1, imagen 1 de 1
    • Turn the power off by pressing a button named 2NDF located in the top-left corner.
    • Press the button named ON/C in the top-right corner.
  2. How to Fix a Stuck Button in Sharp Calculator: paso 2, imagen 1 de 2 How to Fix a Stuck Button in Sharp Calculator: paso 2, imagen 2 de 2
    • Flip the calculator over so that the back panel is facing upwards.
    • Remove two 5mm Phillips #0 screws from the battery cover by turning the screwdriver in a counter-clockwise direction.
    • Remove the remaining four 5mm Phillips #0 screws from the back panel cover.
  3. How to Fix a Stuck Button in Sharp Calculator: paso 3, imagen 1 de 1
    • Remove the battery cover.
    • Insert a spudger into the slot located in the top-right corner and pry the battery out.
  4. How to Fix a Stuck Button in Sharp Calculator: paso 4, imagen 1 de 1
    • Remove the front panel by sticking an opening tool into a small gap between front and back panel.
    • Push the tool down with force and pry open the right side carefully.
    • Detach the front panel from the back panel by lifting the front board.
    • Separate the front and back panel slowly to avoid damaging the LCD ribbon.
  5. How to Fix a Stuck Button in Sharp Calculator: paso 5, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws from the motherboard.
  6. How to Fix a Stuck Button in Sharp Calculator: paso 6, imagen 1 de 2 How to Fix a Stuck Button in Sharp Calculator: paso 6, imagen 2 de 2
    • Lift the motherboard by holding both sides and placing it on the top panel.
    • Lift the grey padding upwards by holding any corner and place it on top of the motherboard.
    • Press the grey padding and put pressure downward to avoid sticking from physical buttons.
  7. How to Fix a Stuck Button in Sharp Calculator: paso 7, imagen 1 de 2 How to Fix a Stuck Button in Sharp Calculator: paso 7, imagen 2 de 2
    • Use a spudger to flip, remove, and adjust the position of buttons.
    • Ensure the placement of buttons is correct. Use STEP 1 Image as a reference to the location of buttons.
Conclusión
2 personas más completaron esta guía.
Documentos Adjuntos
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 5,417
