Saltar al contenido principal
How to Fix a Brazilian Hammock
Qué necesitas
  1. How to Fix a Brazilian Hammock, How to Fix a Brazilian Hammock: paso 1, imagen 1 de 1
    • Place the hammock on a flat surface.
    • Use scissors to cut the frayed ends from the damaged area.
  2. How to Fix a Brazilian Hammock: paso 2, imagen 1 de 2 How to Fix a Brazilian Hammock: paso 2, imagen 2 de 2
    • Align both sides of the tear leaving a quarter-inch gap between both sides of the tear.
    • Use safety pins to temporarily hold both sides of the tear together.
  3. How to Fix a Brazilian Hammock: paso 3, imagen 1 de 1
    • Cut a patch of the Ripstop fabric slightly larger than the tear.
  4. How to Fix a Brazilian Hammock: paso 4, imagen 1 de 1
    • Place the fabric on top of the tear and using safety pins temporarily hold the fabric to the hammock.
  5. How to Fix a Brazilian Hammock: paso 5, imagen 1 de 3 How to Fix a Brazilian Hammock: paso 5, imagen 2 de 3 How to Fix a Brazilian Hammock: paso 5, imagen 3 de 3
    • Be careful with the sewing needle. The end is very sharp.
    • Thread the needle and tie a knot at the end.
  6. How to Fix a Brazilian Hammock: paso 6, imagen 1 de 3 How to Fix a Brazilian Hammock: paso 6, imagen 2 de 3 How to Fix a Brazilian Hammock: paso 6, imagen 3 de 3
    • This step requires basic sewing skills but is easy to accomplish with time.
    • Use the threaded needle to sew from the bottom of the patch up and around the perimeter.
    • Make sure the needle and thread go through the patch and existing hammock material.
  7. How to Fix a Brazilian Hammock: paso 7, imagen 1 de 1
    • When finished tie a knot at the end of the stitch.
    • Make sure the knot is large enough, so it does not slip through the stitches.
  8. How to Fix a Brazilian Hammock: paso 8, imagen 1 de 2 How to Fix a Brazilian Hammock: paso 8, imagen 2 de 2
    • Remove all the safety pins and appreciate your work.
Conclusión
This guide is now completed, enjoy your newly restored hammock.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 104
