Saltar al contenido principal
Hover-1 XLS LCD Screen Replacement
Qué necesitas
  1. Hover-1 XLS LCD Screen Replacement, Ignition: paso 1, imagen 1 de 1
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS LCD Screen Replacement: paso 2, imagen 1 de 3 Hover-1 XLS LCD Screen Replacement: paso 2, imagen 2 de 3 Hover-1 XLS LCD Screen Replacement: paso 2, imagen 3 de 3
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
  4. Hover-1 XLS LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: paso 4, imagen 3 de 3
    • Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
    • Remove the casing on the LCD.
  5. Hover-1 XLS LCD Screen Replacement: paso 5, imagen 1 de 3 Hover-1 XLS LCD Screen Replacement: paso 5, imagen 2 de 3 Hover-1 XLS LCD Screen Replacement: paso 5, imagen 3 de 3
    • Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
    • Gently lift off the LCD screen.
    • Follow iFixit's soldering guide to remove the LCD screen.
Conclusión
Equipo
Cal Poly, Team S1-G2, White Winter 2019 Miembro de Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 33
Todo El Tiempo: 1,225
