Saltar al contenido principal
Hover-1 Eagle Throttle/Brake Lever Replacement
Qué necesitas
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: paso 1, imagen 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: paso 1, imagen 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: paso 1, imagen 3 de 3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: paso 2, imagen 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 2, imagen 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 2, imagen 3 de 3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: paso 3, imagen 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 3, imagen 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 3, imagen 3 de 3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: paso 4, imagen 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 4, imagen 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 4, imagen 3 de 3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: paso 5, imagen 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 5, imagen 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: paso 5, imagen 3 de 3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
Linea de Meta
4 personas más completaron esta guía.
Andrew Gaskell
Miembro Desde 01/23/20
1,008 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G2, White Winter 2020 Miembro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Miembros
6 Guías creadas
24 comentarios
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - Contestar
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - Contestar
Necesito acelerador y no lo encuentro.
Josue Villanueva - Contestar
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 110
Todo El Tiempo: 15,648
