Saltar al contenido principal
Hover-1 Eagle LED Headlight Replacement
Qué necesitas
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: paso 1, imagen 1 de 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: paso 1, imagen 2 de 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: paso 1, imagen 3 de 3
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
  2. Hover-1 Eagle LED Headlight Replacement: paso 2, imagen 1 de 3 Hover-1 Eagle LED Headlight Replacement: paso 2, imagen 2 de 3 Hover-1 Eagle LED Headlight Replacement: paso 2, imagen 3 de 3
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
  3. Hover-1 Eagle LED Headlight Replacement: paso 3, imagen 1 de 2 Hover-1 Eagle LED Headlight Replacement: paso 3, imagen 2 de 2
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
  4. Hover-1 Eagle LED Headlight Replacement: paso 4, imagen 1 de 3 Hover-1 Eagle LED Headlight Replacement: paso 4, imagen 2 de 3 Hover-1 Eagle LED Headlight Replacement: paso 4, imagen 3 de 3
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
Conclusión
4 personas más completaron esta guía.
Andrew Gaskell
Miembro Desde 01/23/20
1,008 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G2, White Winter 2020 Miembro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 1,074
