Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Hover-1 Eagle Front Wheel Replacement
Qué necesitas
  1. Hover-1 Eagle Front Wheel Replacement, Front Wheel: paso 1, imagen 1 de 1
    • Wedge the spudger underneath the red reflective sticker and peel it back.
    Pregunta a FixBot
    Agregar Comentario
  2. Hover-1 Eagle Front Wheel Replacement: paso 2, imagen 1 de 2 Hover-1 Eagle Front Wheel Replacement: paso 2, imagen 2 de 2
    • Remove the four 2mm screws with a Phillips #2 screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  3. Hover-1 Eagle Front Wheel Replacement: paso 3, imagen 1 de 1
    • Remove the plastic axle cover by sliding the cover downwards.
    Pregunta a FixBot
    Agregar Comentario
  4. Hover-1 Eagle Front Wheel Replacement: paso 4, imagen 1 de 1
    • Use pliers to remove the locknut.
    Pregunta a FixBot
    Agregar Comentario
  5. Hover-1 Eagle Front Wheel Replacement: paso 5, imagen 1 de 1
    • Slide the wheel out in a downwards motion to remove it from the fork.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Andrew Gaskell
Miembro Desde 01/23/20
1,137 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G2, White Winter 2020 Miembro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
Miembros de 4
6 Guías creadas
18Guía Comentarios
Good afternoon.
And how do you remove the cables?
Diogo Silva - Contestar Compartir
i would like to know the same thing
it'sluigiplays 87 - Contestar Compartir
where do i get the front wheel front i cant find where to buy a new front wheel
leon watts - Contestar Compartir
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
Mk Sub-zero - Contestar Compartir
Does anybody know how to fix the handlebar/front wheel alignment?
robandkim - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 101
Todo El Tiempo: 7,853
