Saltar al contenido principal
Hover-1 Eagle Front Wheel Replacement
Qué necesitas
  1. Hover-1 Eagle Front Wheel Replacement, Front Wheel: paso 1, imagen 1 de 1
    • Wedge the spudger underneath the red reflective sticker and peel it back.
  2. Hover-1 Eagle Front Wheel Replacement: paso 2, imagen 1 de 2 Hover-1 Eagle Front Wheel Replacement: paso 2, imagen 2 de 2
    • Remove the four 2mm screws with a Phillips #2 screwdriver.
  3. Hover-1 Eagle Front Wheel Replacement: paso 3, imagen 1 de 1
    • Remove the plastic axle cover by sliding the cover downwards.
  4. Hover-1 Eagle Front Wheel Replacement: paso 4, imagen 1 de 1
    • Use pliers to remove the locknut.
  5. Hover-1 Eagle Front Wheel Replacement: paso 5, imagen 1 de 1
    • Slide the wheel out in a downwards motion to remove it from the fork.
Conclusión
2 personas más completaron esta guía.
Andrew Gaskell
Miembro Desde 01/23/20
903 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G2, White Winter 2020 Miembro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Miembros
5 Guías creadas
13 comentarios
Good afternoon.
And how do you remove the cables?
Diogo Silva - Contestar
i would like to know the same thing
it'sluigiplays 87 - Contestar
where do i get the front wheel front i cant find where to buy a new front wheel
leon watts - Contestar
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
Mk Sub-zero - Contestar
Does anybody know how to fix the handlebar/front wheel alignment?
robandkim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 132
Todo El Tiempo: 5,017
