Saltar al contenido principal
Hover-1 Eagle Back Wheel Replacement
Qué necesitas
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: paso 1, imagen 1 de 1
    • Peel off the reflective red axle sticker using a plastic spudger.
  2. Hover-1 Eagle Back Wheel Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
  3. Hover-1 Eagle Back Wheel Replacement: paso 3, imagen 1 de 3 Hover-1 Eagle Back Wheel Replacement: paso 3, imagen 2 de 3 Hover-1 Eagle Back Wheel Replacement: paso 3, imagen 3 de 3
    • Grip the deck flare and slide it towards the tail end of the scooter.
  4. Hover-1 Eagle Back Wheel Replacement: paso 4, imagen 1 de 1
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
  5. Hover-1 Eagle Back Wheel Replacement: paso 5, imagen 1 de 3 Hover-1 Eagle Back Wheel Replacement: paso 5, imagen 2 de 3 Hover-1 Eagle Back Wheel Replacement: paso 5, imagen 3 de 3
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
  6. Hover-1 Eagle Back Wheel Replacement: paso 6, imagen 1 de 2 Hover-1 Eagle Back Wheel Replacement: paso 6, imagen 2 de 2
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
Conclusión
To reassemble your device, repeat Steps 1-4 in reverse order.
4 personas más completaron esta guía.
Andrew Gaskell
Miembro Desde 01/23/20
1,008 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G2, White Winter 2020 Miembro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Miembros
6 Guías creadas
Un comentario
Where do you buy the wheels
Thanks
antonio flores - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 8
Ultimos 30 días: 76
Todo El Tiempo: 2,369
