Saltar al contenido principal
Hover-1 Charger LED Headlight Replacement
Qué necesitas
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: paso 1, imagen 1 de 2 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: paso 1, imagen 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: paso 2, imagen 1 de 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: paso 3, imagen 1 de 2 Hover-1 Charger LED Headlight Replacement: paso 3, imagen 2 de 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: paso 4, imagen 1 de 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: paso 5, imagen 1 de 2 Hover-1 Charger LED Headlight Replacement: paso 5, imagen 2 de 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: paso 6, imagen 1 de 2 Hover-1 Charger LED Headlight Replacement, LED Headlight: paso 6, imagen 2 de 2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: paso 7, imagen 1 de 2 Hover-1 Charger LED Headlight Replacement: paso 7, imagen 2 de 2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: paso 8, imagen 1 de 1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
Conclusión
Benji Forest
Miembro Desde 10/10/19
266 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S12-G1, Regan Fall 2019 Miembro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 226
