Saltar al contenido principal
Hover-1 Charger Gyroscope Sensor Board Replacement
Qué necesitas
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: paso 1, imagen 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: paso 1, imagen 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 2, imagen 1 de 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 3, imagen 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement: paso 3, imagen 2 de 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 4, imagen 1 de 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 5, imagen 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement: paso 5, imagen 2 de 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: paso 6, imagen 1 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: paso 6, imagen 2 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: paso 6, imagen 3 de 3
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 7, imagen 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement: paso 7, imagen 2 de 2
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 8, imagen 1 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement: paso 8, imagen 2 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement: paso 8, imagen 3 de 3
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: paso 9, imagen 1 de 1
    • Remove the gyroscope sensor board.
Conclusión
Una persona más ha completado esta guía.
Melanie Hardell
Miembro Desde 10/10/19
505 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S12-G1, Regan Fall 2019 Miembro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Miembros
6 Guías creadas
4 comentarios
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - Contestar
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - Contestar
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - Contestar
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 81
Todo El Tiempo: 4,754
