Saltar al contenido principal
Hover-1 Charger Bluetooth Speaker Replacement
Qué necesitas
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: paso 1, imagen 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: paso 1, imagen 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: paso 2, imagen 1 de 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: paso 3, imagen 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: paso 3, imagen 2 de 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: paso 4, imagen 1 de 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: paso 5, imagen 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: paso 5, imagen 2 de 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: paso 6, imagen 1 de 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: paso 7, imagen 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: paso 7, imagen 2 de 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: paso 8, imagen 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: paso 9, imagen 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: paso 9, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: paso 10, imagen 1 de 1
    • Remove the speaker and circuit board from the outer shell.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S12-G1, Regan Fall 2019 Miembro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 32
Todo El Tiempo: 1,354
