Saltar al contenido principal
Hott T725-8G Screen/Display Replacement
Qué necesitas
  1. Hott T725-8G Screen/Display Replacement, Screen/Display: paso 1, imagen 1 de 1
    • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
  2. Hott T725-8G Screen/Display Replacement: paso 2, imagen 1 de 1
    • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
  3. Hott T725-8G Screen/Display Replacement: paso 3, imagen 1 de 1
    • Dislodge the sensor from the front panel.
  4. Hott T725-8G Screen/Display Replacement: paso 4, imagen 1 de 2 Hott T725-8G Screen/Display Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
  5. Hott T725-8G Screen/Display Replacement: paso 5, imagen 1 de 3 Hott T725-8G Screen/Display Replacement: paso 5, imagen 2 de 3 Hott T725-8G Screen/Display Replacement: paso 5, imagen 3 de 3
    • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
  6. Hott T725-8G Screen/Display Replacement: paso 6, imagen 1 de 1
    • Follow the guide to remove the motherboard from the back of the display.
  7. Hott T725-8G Screen/Display Replacement: paso 7, imagen 1 de 1
    • Follow the guide to remove the battery from the back of the display.
  8. Hott T725-8G Screen/Display Replacement: paso 8, imagen 1 de 1
    • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
  9. Hott T725-8G Screen/Display Replacement: paso 9, imagen 1 de 1
    • Remove Digitizer Panel from the front panel.
  10. Hott T725-8G Screen/Display Replacement: paso 10, imagen 1 de 1
    • Remove the LCD 5-Point Touch Screen from the display case.
  11. Hott T725-8G Screen/Display Replacement: paso 11, imagen 1 de 1
    • Remove the display from the plastic casing. The screen is now ready for replacement.
Conclusión
2 personas más completaron esta guía.
Emma Carroll
Miembro Desde 10/20/16
193 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 6-2, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 315
