Introducción
This guide shows how to replace the rotation button that controls the oscillation of your fan. Replacing the rotation button requires soldering, so it may be a little tricky for those of you who are inexperienced with soldering.
Qué necesitas
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
Remove the two 10mm Phillips #0 screws that are located next to the rotation button.
