Saltar al contenido principal
Honeywell HY-204 Control Panel Replacement
Qué necesitas
  1. Honeywell HY-204 Control Panel Replacement, Case: paso 1, imagen 1 de 2 Honeywell HY-204 Control Panel Replacement, Case: paso 1, imagen 2 de 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: paso 2, imagen 1 de 2 Honeywell HY-204 Control Panel Replacement: paso 2, imagen 2 de 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: paso 3, imagen 1 de 2 Honeywell HY-204 Control Panel Replacement, Control Panel: paso 3, imagen 2 de 2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: paso 4, imagen 1 de 1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Conclusión
Nolan Ernotte
Miembro Desde 10/14/14
366 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-40, Amido Fall 2014 Miembro de Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 508
