Saltar al contenido principal
HomePod Mini speaker Replacement
Qué necesitas
    • turn homepod mini upside down
    • peel back the foot cover
    • carefully cut the fabric mesh using the fabric scissors
    • be very careful not to scratch the delicate glass surface on top
    • unscrew the 4 torx screws on the bottom near the speaker holes
    • carefully seperate the top and middle sections from the homepod mini
    • be very careful when separating as there are cables connected to the motherboard as well as the speakers
    • carefully unplug all the cables connected to the motherboard
    • carefully separate the middle section of the homepod mini
    • carefully remove the speaker driver from the bottom part of the homepod mini
    • be very careful not to damage the delicate ribbon cable below the driver
    • remove the speaker driver
    • carefully remove the cables connecting to the driver being careful not to damage it
Conclusión
776831
Miembro Desde 06/10/21
1,085 Reputación
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 49
Todo El Tiempo: 128
