Introducción
This guide involves the manipulation of small, intricate parts. Please use caution.
Before disassembling your device, please refer to the troubleshooting guide to investigate other possible solutions to your problem.
Qué necesitas
Remove the front two hub caps.
When finished, you should be able to remove the back cover.
Unscrew all of the screws that you can access on the hard drive.
If you cannot reach the screw beneath the black strip, move on to the next step.
Una persona más ha completado esta guía.
