Saltar al contenido principal
Hisense Chromebook C11 Hard Drive Replacement
Qué necesitas
  1. Hisense Chromebook C11 Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Hard Drive Replacement, Battery: paso 4, imagen 1 de 1
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with the Phillips #000 screwdriver.
  5. Hisense Chromebook C11 Hard Drive Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to unplug the battery.
  6. Hisense Chromebook C11 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the battery.
  7. Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 2 Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: paso 7, imagen 2 de 2
    • Unscrew all of the screws that you can access on the hard drive.
    • If you cannot reach the screw beneath the black strip, move on to the next step.
  8. Hisense Chromebook C11 Hard Drive Replacement: paso 8, imagen 1 de 3 Hisense Chromebook C11 Hard Drive Replacement: paso 8, imagen 2 de 3 Hisense Chromebook C11 Hard Drive Replacement: paso 8, imagen 3 de 3
    Comprar
    • Remove the black strip using the tweezers.
  9. Hisense Chromebook C11 Hard Drive Replacement: paso 9, imagen 1 de 1
    • Unscrew the screw beneath the black strip if you haven't done so already.
  10. Hisense Chromebook C11 Hard Drive Replacement: paso 10, imagen 1 de 2 Hisense Chromebook C11 Hard Drive Replacement: paso 10, imagen 2 de 2
    • Remove the ribbon with the tweezers.
  11. Hisense Chromebook C11 Hard Drive Replacement: paso 11, imagen 1 de 2 Hisense Chromebook C11 Hard Drive Replacement: paso 11, imagen 2 de 2
    • Using the tweezers, carefully remove the latches attaching the silver computer chip.
  12. Hisense Chromebook C11 Hard Drive Replacement: paso 12, imagen 1 de 2 Hisense Chromebook C11 Hard Drive Replacement: paso 12, imagen 2 de 2
    • Continue gently removing all remaining points of attachment.
  13. Hisense Chromebook C11 Hard Drive Replacement: paso 13, imagen 1 de 1
    • Carefully remove the hard drive.
Conclusión
Una persona más ha completado esta guía.
Chelsea Charles
Miembro Desde 10/09/18
422 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 1,166
