Saltar al contenido principal
Headlight Bulb Replacement
Qué necesitas
  1. Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 1 de 1
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
    • Vinyl or latex gloves are great if you have them available, but not required.
  2. Headlight Bulb Replacement: paso 2, imagen 1 de 2 Headlight Bulb Replacement: paso 2, imagen 2 de 2
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. Headlight Bulb Replacement: paso 3, imagen 1 de 3 Headlight Bulb Replacement: paso 3, imagen 2 de 3 Headlight Bulb Replacement: paso 3, imagen 3 de 3
    • Lift up and remove the metal wire cage holding the bulb in place.
  4. Headlight Bulb Replacement: paso 4, imagen 1 de 1
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
Conclusión
To replace the bulb, follow the steps in reverse order.
Una persona más ha completado esta guía.
Tim Asp
Miembro Desde 01/24/11
2,452 Reputación
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 3,407
