Saltar al contenido principal
Hatch Restore Bottom Circuit Board Replacement
Qué necesitas
  1. Hatch Restore Bottom Circuit Board Replacement, Intro: paso 1, imagen 1 de 2 Hatch Restore Bottom Circuit Board Replacement, Intro: paso 1, imagen 2 de 2
    • Replacing your bottom circuit board will be easy.
  2. Hatch Restore Bottom Circuit Board Replacement: paso 2, imagen 1 de 2 Hatch Restore Bottom Circuit Board Replacement: paso 2, imagen 2 de 2
    • Peel away the rubber feet.
  3. Hatch Restore Bottom Circuit Board Replacement: paso 3, imagen 1 de 2 Hatch Restore Bottom Circuit Board Replacement: paso 3, imagen 2 de 2
    • Remove the indicated 8 screws.
    • You may need to remove some adhesive from the screws to remove them.
  4. Hatch Restore Bottom Circuit Board Replacement: paso 4, imagen 1 de 2 Hatch Restore Bottom Circuit Board Replacement: paso 4, imagen 2 de 2
    • Pry off the bottom cover.
  5. Hatch Restore Bottom Circuit Board Replacement: paso 5, imagen 1 de 1
    • Remove the 6 indicated screws.
  6. Hatch Restore Bottom Circuit Board Replacement: paso 6, imagen 1 de 2 Hatch Restore Bottom Circuit Board Replacement: paso 6, imagen 2 de 2
    • Remove the power cable
    • There is a ribbon cable under the board. Do not pull the circuit board too far from the device.
  7. Hatch Restore Bottom Circuit Board Replacement: paso 7, imagen 1 de 2 Hatch Restore Bottom Circuit Board Replacement: paso 7, imagen 2 de 2
    • Push the black tabs on the ZIF connector towards the cable, then remove the cable.
    • The cable should have no resistance when pulled out. Do not forcefully remove the cable.
Conclusión
9021007
Miembro Desde 07/13/18
4,599 Reputación
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 261
