Saltar al contenido principal
Hamilton-C3 Battery Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Hamilton-C3 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Connect the ventilator to an external power source. There is a two-prong cable that can be connected to a port on the backside of the ventilator.
    • It is vital that external power is present so that ventilation may continue even without a working battery in place.
  2. Hamilton-C3 Battery Replacement: paso 2, imagen 1 de 2 Hamilton-C3 Battery Replacement: paso 2, imagen 2 de 2
    • Open the battery door on the left side (facing the moniter) of the ventilator.
  3. Hamilton-C3 Battery Replacement: paso 3, imagen 1 de 1
    • Twist the metal locking clip (indicated by red arrow) counterclockwise out of the locking position.
    • Use any flathead screwdriver to accomplish this task.
    • During reassembly, turn the metal locking clip (in red) clockwise, back into the locked position, to keep the battery secure.
    • Push the latch (component in red) upwards.
  4. Hamilton-C3 Battery Replacement: paso 4, imagen 1 de 1
    • While pushing up the retaining clip, remove the battery (follow the blue arrow, ignore the white arrow).
    • During reassembly, push the new battery in until the latch (circled in red) locks down.
  5. Hamilton-C3 Battery Replacement: paso 5, imagen 1 de 1
    • Turn the metal locking clip (in red) clockwise back into the locked position to keep the battery secure.
Conclusión
Lucas Rasmussen
Miembro Desde 04/23/18
2,211 Reputación
11 Guías creadas
Equipo
Cal Poly, Team S7-G1, Paton Spring 2020 Miembro de Cal Poly, Team S7-G1, Paton Spring 2020
CPSU-PATON-S20S7G1
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 278
