Introducción
This guide may be useful for users who are experiencing power issues. This procedure requires a high technical skill in electrical soldering, along with moderate electrical wiring skills.
Qué necesitas
Paso 1 Base Removal
Aviso: los pasos 1-5 provienen de una guía que está marcada como "En progreso".
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
Solder the highlighted section of the power cord, and undo the wiring. Using soldering wire connect a new line with the soldering iron.
