Introducción
The HTC Vive's motherboard can break due to electrical shorts, water damage, or factory defects. This guide will show you how to replace the motherboard. If your Vive is still broken after finishing this guide, see the HTC Vive Troubleshooting Guide for additional solutions.
Herramientas
Partes
No se especificaron partes.
Slide the HTC panel covering the cables forward, away from the Vive.
Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
Pull the facerest cushion off away from the Vive, separating the hook and loop tape.
Orient the Vive so that the camera is facing towards you and the connector ports are facing upwards.
There are four screws you need to remove that are covered with small black stickers (two on top, two on bottom).
Use a plastic opening tool to gently pry up the left side of the outer sheath.
Slide the left side of the sheath outwards.
Remove the five 4mm Philips #00 screws holding the sensor array to the motherboard.
Remove the two 4mm Philips #00 screws holding the sensor array to the midframe.
Lift the sensor array away from the rest of the Vive until the camera cable tugs back and hold it in place.
Disconnect the camera by lifting its ribbon cable up and away from the motherboard using a pair of ESD safe tweezers.
Lift the sensor array upwards away from the motherboard to separate the array from the device fully.
Loosen the three ribbon cables that are attached to the motherboard by grabbing the tabs on the side of the ribbon cables' connectors and pulling gently outwards.
Fully detach the same three ribbon cables by grabbing each cable with tweezers and sliding them outwards horizontally.
7 personas más completaron esta guía.
4 comentarios
Any recommendations as to where to find a motherboard for the vive? Having trouble getting google to stop recommending motherboards that support vr.
You may (or may not) have luck trying to grab Vives with different broken parts off of eBay.
is that really the only way?
Gus -
Anyone know where to get a replacement vive motherboard? Even if it’s from china
