Introducción
The HTC Vive's focus knob may wear down or crack with use. This guide will show you how to replace the Vive's focus knob.
Herramientas
Partes
Slide the HTC panel covering the cables forward, away from the Vive.
Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
Pull the facerest cushion off away from the Vive, separating the hook and loop tape.
Orient the Vive so that the camera is facing towards you and the connector ports are facing upwards.
There are four screws you need to remove that are covered with small black stickers (two on top, two on bottom).
Use a plastic opening tool to gently pry up the left side of the outer sheath.
Slide the left side of the sheath outwards.
Remove the focus knob by unscrewing one 4mm #00 Philips head screw.
Pull the knob outwards from the device.
Una persona más ha completado esta guía.
