Saltar al contenido principal
HTC One Speaker Replacement
Qué necesitas
  1. HTC One Speaker Replacement, Speaker: paso 1, imagen 1 de 3 HTC One Speaker Replacement, Speaker: paso 1, imagen 2 de 3 HTC One Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: paso 2, imagen 1 de 1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: paso 3, imagen 1 de 1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: paso 6, imagen 1 de 2 HTC One Speaker Replacement: paso 6, imagen 2 de 2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: paso 7, imagen 1 de 2 HTC One Speaker Replacement: paso 7, imagen 2 de 2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: paso 8, imagen 1 de 3 HTC One Speaker Replacement: paso 8, imagen 2 de 3 HTC One Speaker Replacement: paso 8, imagen 3 de 3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: paso 9, imagen 1 de 2 HTC One Speaker Replacement: paso 9, imagen 2 de 2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Conclusión
16 personas más completaron esta guía.
Alex
Miembro Desde 09/23/14
664 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 12-1, Blackwell Fall 2014 Miembro de USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Miembros
7 Guías creadas
2 comentarios
Where to buy speaker???
bharatdshmkh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 19,455
