Introducción
Give your phone a battery boost by replacing the battery in your HTC One S.
Herramientas
Partes
No se especificaron partes.
Handling it by the tag, place the heated iOpener across the bottom casing.
Using the pointed end of a spudger, lift the battery cable and release the connector.
12 personas más completaron esta guía.
4 comentarios
Hello thank you for the guide. Getting the backplate off was tough. When assembling a little rubber block was loose. this goes next to the motor
