Saltar al contenido principal
HP Z2 Mini G3 Real-Time Clock Battery Replacement
  1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: paso 1, imagen 1 de 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: paso 2, imagen 1 de 2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: paso 2, imagen 2 de 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: paso 3, imagen 1 de 2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: paso 3, imagen 2 de 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: paso 4, imagen 1 de 1
    • Rotate the device so the back-side is facing you and locate the RTC battery.
    • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
  5. HP Z2 Mini G3 Real-Time Clock Battery Replacement: paso 5, imagen 1 de 1
    • Press the battery down and away to free it of the latches.
    • Use your hand to grab and lift the battery out of the socket.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 122
Todo El Tiempo: 2,249
