Saltar al contenido principal
HP Stream 11-d020nr Webcam Replacement
Qué necesitas
  1. HP Stream 11-d020nr Webcam Replacement, Lower Case: paso 1, imagen 1 de 3 HP Stream 11-d020nr Webcam Replacement, Lower Case: paso 1, imagen 2 de 3 HP Stream 11-d020nr Webcam Replacement, Lower Case: paso 1, imagen 3 de 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Webcam Replacement: paso 2, imagen 1 de 2 HP Stream 11-d020nr Webcam Replacement: paso 2, imagen 2 de 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Webcam Replacement: paso 3, imagen 1 de 3 HP Stream 11-d020nr Webcam Replacement: paso 3, imagen 2 de 3 HP Stream 11-d020nr Webcam Replacement: paso 3, imagen 3 de 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Webcam Replacement: paso 4, imagen 1 de 3 HP Stream 11-d020nr Webcam Replacement: paso 4, imagen 2 de 3 HP Stream 11-d020nr Webcam Replacement: paso 4, imagen 3 de 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Webcam Replacement, Keyboard: paso 5, imagen 1 de 2 HP Stream 11-d020nr Webcam Replacement, Keyboard: paso 5, imagen 2 de 2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
  6. HP Stream 11-d020nr Webcam Replacement: paso 6, imagen 1 de 3 HP Stream 11-d020nr Webcam Replacement: paso 6, imagen 2 de 3 HP Stream 11-d020nr Webcam Replacement: paso 6, imagen 3 de 3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
  7. HP Stream 11-d020nr Webcam Replacement, Lid: paso 7, imagen 1 de 3 HP Stream 11-d020nr Webcam Replacement, Lid: paso 7, imagen 2 de 3 HP Stream 11-d020nr Webcam Replacement, Lid: paso 7, imagen 3 de 3
    • Lift the black flap on the display cable ZIF connector.
    • After lifting the flap, gently pull the display cable from its socket.
    • Disconnect the wireless antenna from the wireless card.
    • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
  8. HP Stream 11-d020nr Webcam Replacement: paso 8, imagen 1 de 3 HP Stream 11-d020nr Webcam Replacement: paso 8, imagen 2 de 3 HP Stream 11-d020nr Webcam Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to remove the screw covers from the lid.
    • Remove the two 2.2 mm Phillips #000 screws.
    • Use a plastic opening tool to disengage the front part of the lid.
  9. HP Stream 11-d020nr Webcam Replacement, Webcam: paso 9, imagen 1 de 1
    • Use the tweezers to remove the wire connected to the webcam.
  10. HP Stream 11-d020nr Webcam Replacement: paso 10, imagen 1 de 1
    • Use the tweezers to pull the webcam off of the frame.
Conclusión
2 personas más completaron esta guía.
Spenser Mason
Miembro Desde 02/04/16
1,763 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-5, Wollert Spring 2016 Miembro de USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
Miembros de 5
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 482
