Saltar al contenido principal
HP Stream 11-d008TU Battery Connector Unplugging
Qué necesitas
  1. HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: paso 1, imagen 1 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: paso 1, imagen 2 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: paso 1, imagen 3 de 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: paso 2, imagen 1 de 2 HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: paso 2, imagen 2 de 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: paso 3, imagen 1 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: paso 3, imagen 2 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: paso 3, imagen 3 de 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: paso 4, imagen 1 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: paso 4, imagen 2 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: paso 4, imagen 3 de 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: paso 5, imagen 1 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: paso 5, imagen 2 de 3 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: paso 5, imagen 3 de 3
    • Locate the white plastic connector on the motherboard
    • Peel back the black tape holding the cable's wires in place
    • Pull the white connector out by puling the white plastic away from the connector
    • Do not grab the connector by the wires
Conclusión
Una persona más ha completado esta guía.
Joel Taylor
Miembro Desde 03/07/20
1,298 Reputación
8 Guías creadas
Equipo
Australia Miembro de Australia
Community
Miembros de 4
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 104
