Introducción
This guide will give you step-by-step instructions on how to remove your battery. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your battery actually needs to be replaced by consulting our troubleshooting guide.
Qué necesitas
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
For optimal performance, after completing this guide, calibrate your newly installed battery.
7 personas más completaron esta guía.
5 comentarios
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Thanks! I will correct the step with the right screw size.
