Qué necesitas
Turn off the tablet and disconnect the power and all external devices from the tablet.
Position the tablet with the display panel down and the right side toward you.
Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
Remove the four screws from the motherboard using a Phillips 00 screwdriver.
Remove the two grey wires on the left and the four multicolored wires on the right by desoldering them. See iFixit guide on how to solder.
Una persona más ha completado esta guía.
