Saltar al contenido principal
HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement
Qué necesitas
  1. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement, Tablet Cover: paso 1, imagen 1 de 1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 2, imagen 1 de 2 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 2, imagen 2 de 2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 3, imagen 1 de 3 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 3, imagen 2 de 3 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 3, imagen 3 de 3
    • Pry open the back cover to take it off.
  4. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement, Battery: paso 4, imagen 1 de 3 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement, Battery: paso 4, imagen 2 de 3 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement, Battery: paso 4, imagen 3 de 3
    • Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
    • The battery cables are soldered to the system in the following sequence, top to bottom: red, blue, green, yellow, black.
  5. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 5, imagen 1 de 3 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 5, imagen 2 de 3 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 5, imagen 3 de 3
    • Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
    • The battery is attached to the display panel assembly with double-sided adhesive. Make sure to firmly pull the battery.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  6. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement, Rear Facing Webcamera: paso 6, imagen 1 de 2 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement, Rear Facing Webcamera: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the black foam stickers from the rear facing camera to expose the wiring.
  7. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 7, imagen 1 de 2 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 7, imagen 2 de 2
    • Using tweezers, lift the camera out from system board.
  8. HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 8, imagen 1 de 2 HP Slate 7 Plus 4200US Rear Facing Webcamera Replacement: paso 8, imagen 2 de 2
    • Use tweezers to pull the wire out from the connector. Pull away from the connector, parallel to the tablet.
Conclusión
Equipo
USF Tampa, Team 3-1, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G1
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 102
