Saltar al contenido principal
HP Slate 7 Plus 4200US Battery Replacement
Qué necesitas
  1. HP Slate 7 Plus 4200US Battery Replacement, Tablet Cover: paso 1, imagen 1 de 1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Battery Replacement: paso 2, imagen 1 de 2 HP Slate 7 Plus 4200US Battery Replacement: paso 2, imagen 2 de 2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Battery Replacement: paso 3, imagen 1 de 3 HP Slate 7 Plus 4200US Battery Replacement: paso 3, imagen 2 de 3 HP Slate 7 Plus 4200US Battery Replacement: paso 3, imagen 3 de 3
    • Pry open the back cover to take it off.
  4. HP Slate 7 Plus 4200US Battery Replacement, Battery: paso 4, imagen 1 de 3 HP Slate 7 Plus 4200US Battery Replacement, Battery: paso 4, imagen 2 de 3 HP Slate 7 Plus 4200US Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
    • The battery cables are soldered to the system in the following sequence, top to bottom: red, blue, green, yellow, black.
  5. HP Slate 7 Plus 4200US Battery Replacement: paso 5, imagen 1 de 3 HP Slate 7 Plus 4200US Battery Replacement: paso 5, imagen 2 de 3 HP Slate 7 Plus 4200US Battery Replacement: paso 5, imagen 3 de 3
    • Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
    • The battery is attached to the display panel assembly with double-sided adhesive. Make sure to firmly pull the battery.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
Conclusión
Una persona más ha completado esta guía.
Jessica Andrade
Miembro Desde 10/04/16
860 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 3-1, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G1
3 Miembros
14 Guías creadas
Un comentario
Bonjour, où peut on trouver une batterie svp ?
C'est pour une tablette HP Slate7 Plus.
Merci pour votre aide.
Cordialement. Stéphane
dingo346 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 2,082
