Saltar al contenido principal
HP Pavilion x360 m3-u001dx Display Replacement
Qué necesitas
  1. HP Pavilion x360 m3-u001dx Display Replacement, Keyboard: paso 1, imagen 1 de 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Display Replacement: paso 2, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 2, imagen 2 de 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Display Replacement: paso 3, imagen 1 de 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Display Replacement: paso 4, imagen 1 de 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Display Replacement: paso 5, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 5, imagen 2 de 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Display Replacement: paso 6, imagen 1 de 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Display Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Heavy-Duty Spudger
    Comprar
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Display Replacement: paso 8, imagen 1 de 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Display Replacement, Battery: paso 9, imagen 1 de 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Display Replacement: paso 10, imagen 1 de 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Display Replacement, USB Port Shield: paso 11, imagen 1 de 3 HP Pavilion x360 m3-u001dx Display Replacement, USB Port Shield: paso 11, imagen 2 de 3 HP Pavilion x360 m3-u001dx Display Replacement, USB Port Shield: paso 11, imagen 3 de 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  12. HP Pavilion x360 m3-u001dx Display Replacement, System Board (Motherboard): paso 12, imagen 1 de 3 HP Pavilion x360 m3-u001dx Display Replacement, System Board (Motherboard): paso 12, imagen 2 de 3 HP Pavilion x360 m3-u001dx Display Replacement, System Board (Motherboard): paso 12, imagen 3 de 3
    Heavy-Duty Spudger
    Comprar
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u001dx Display Replacement: paso 13, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 13, imagen 2 de 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u001dx Display Replacement: paso 14, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 14, imagen 2 de 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u001dx Display Replacement: paso 15, imagen 1 de 3 HP Pavilion x360 m3-u001dx Display Replacement: paso 15, imagen 2 de 3 HP Pavilion x360 m3-u001dx Display Replacement: paso 15, imagen 3 de 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u001dx Display Replacement: paso 16, imagen 1 de 1
    • Carefully lift the front side of the system board (motherboard).
  17. HP Pavilion x360 m3-u001dx Display Replacement: paso 17, imagen 1 de 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u001dx Display Replacement: paso 18, imagen 1 de 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  19. HP Pavilion x360 m3-u001dx Display Replacement, Display: paso 19, imagen 1 de 1
    • Using the Phillips 00 Screw Driver, remove 5 Phillips 2.5 x 4.2 screws from the hinges from the laptop's base.
  20. HP Pavilion x360 m3-u001dx Display Replacement: paso 20, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 20, imagen 2 de 2
    • Gently pull the display away from the base panel to unhinge.
  21. HP Pavilion x360 m3-u001dx Display Replacement: paso 21, imagen 1 de 1
    • Use a Metal Spudger to pry the display panel from the outer casing.
    • Start from the top of the display panel and move along the edges and do not to push the metal spudger too far into the screen.
    • Be cautious not to apply heavy pressure to the display panel. This could damage the touch screen.
  22. HP Pavilion x360 m3-u001dx Display Replacement: paso 22, imagen 1 de 1
    • Open the display panel to expose the connecting cables.
    • Open carefully to avoid causing damage to the connecting cables.
  23. HP Pavilion x360 m3-u001dx Display Replacement: paso 23, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 23, imagen 2 de 2
    • Peel off the adhesive tape and remove the connected cable from the screen.
  24. HP Pavilion x360 m3-u001dx Display Replacement: paso 24, imagen 1 de 2 HP Pavilion x360 m3-u001dx Display Replacement: paso 24, imagen 2 de 2
    • Lift the circuit board out of the way to expose the wire underneath. Remove the wire from the base of the laptop.
Conclusión
Follow these instructions in reverse order to reassemble your device.
5 personas más completaron esta guía.
_ thinhh@uw.edu
Miembro Desde 02/01/17
297 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team 1-6, Rose Winter 2017 Miembro de UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 Miembros
8 Guías creadas
5 comentarios
Question, why not just do step 21 on?
ETHREAL1 - Contestar
You can. Fold the computer all the way over and go from there. The only advantage to opening the bottom would be to disconnect the battery: a highly recommended procedure.
Corvallis Computer - Contestar
A little extra pulling the mother board out. But I guess better safe then sorry. All in all this was a good guide!
Brandon Courtney - Contestar
REMEMBER if your new touch screen does not work (no touch screen) go into the device manager and uninstall i2c hid device. restart the laptop and the driver (and touch) should work again.
Akeem Scrubb - Contestar
I was able to install a new screen. However, the “touch” does not work. I tried the uninstall i2c hid (and also HID- compliant touch screen) trick, but no luck. My guess is its my fault during install. Before I go diving back in for a loose connection, does anyone know which connection I should focus on?
allynz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 7,321
