Saltar al contenido principal
HP Pavilion x360 14-ba253cl Keyboard Replacement
Qué necesitas
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: paso 3, imagen 1 de 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: paso 4, imagen 1 de 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: paso 5, imagen 1 de 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
Conclusión
Una persona más ha completado esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
85,254 Reputación
215 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,086 Guías creadas
Un comentario
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 71
Todo El Tiempo: 7,159
