Introducción
Over time, audio drivers can go bad due to normal wear or water and dust entering the audio jack. This could result in no audio when using headphones or external speakers connected to the HP Pavilion G60-120US. Before replacing any components, please refer to HP Pavilion G60-120US Troubleshooting. This guide will help users fix the problem by replacing the old broken audio driver with a new one.
Qué necesitas
Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
Using the Phillips #0 screwdriver, remove the four 4mm screws from the midframe.
Lift the black tab on the ribbon cable that connects the audio jack to the motherboard.
Pull the cable out gently and detach it from the motherboard.
