Saltar al contenido principal
HP Pavilion 17-e146us Motherboard Replacement
Qué necesitas
  1. HP Pavilion 17-e146us Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over.
  2. HP Pavilion 17-e146us Motherboard Replacement: paso 2, imagen 1 de 2 HP Pavilion 17-e146us Motherboard Replacement: paso 2, imagen 2 de 2
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. HP Pavilion 17-e146us Motherboard Replacement: paso 3, imagen 1 de 1
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. HP Pavilion 17-e146us Motherboard Replacement, Keyboard: paso 4, imagen 1 de 3 HP Pavilion 17-e146us Motherboard Replacement, Keyboard: paso 4, imagen 2 de 3 HP Pavilion 17-e146us Motherboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. HP Pavilion 17-e146us Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  6. HP Pavilion 17-e146us Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  7. HP Pavilion 17-e146us Motherboard Replacement: paso 7, imagen 1 de 2 HP Pavilion 17-e146us Motherboard Replacement: paso 7, imagen 2 de 2
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  8. HP Pavilion 17-e146us Motherboard Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  9. HP Pavilion 17-e146us Motherboard Replacement: paso 9, imagen 1 de 1
    • Flip device over so that the cover is facing towards you
  10. HP Pavilion 17-e146us Motherboard Replacement: paso 10, imagen 1 de 3 HP Pavilion 17-e146us Motherboard Replacement: paso 10, imagen 2 de 3 HP Pavilion 17-e146us Motherboard Replacement: paso 10, imagen 3 de 3
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
  11. HP Pavilion 17-e146us Motherboard Replacement, Motherboard: paso 11, imagen 1 de 1
    • Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
  12. HP Pavilion 17-e146us Motherboard Replacement: paso 12, imagen 1 de 1
    • Place wedge tool in-between the front panel and the cover underneath the keyboard
    • Use wedge tool to pop the two covers apart.
    • This may require some force.
  13. HP Pavilion 17-e146us Motherboard Replacement: paso 13, imagen 1 de 2 HP Pavilion 17-e146us Motherboard Replacement: paso 13, imagen 2 de 2
    • Remove the motherboard using your hands
    • The motherboard is large green portion located inside the device
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 905
