Saltar al contenido principal
HP Pavilion 15-cd040wm CD Drive Replacement
Qué necesitas
  1. HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: paso 1, imagen 1 de 2 HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: paso 1, imagen 2 de 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm CD Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-cd040wm CD Drive Replacement: paso 2, imagen 2 de 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm CD Drive Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-cd040wm CD Drive Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-cd040wm CD Drive Replacement: paso 3, imagen 3 de 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm CD Drive Replacement, Battery: paso 4, imagen 1 de 2 HP Pavilion 15-cd040wm CD Drive Replacement, Battery: paso 4, imagen 2 de 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm CD Drive Replacement: paso 5, imagen 1 de 2 HP Pavilion 15-cd040wm CD Drive Replacement: paso 5, imagen 2 de 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: paso 6, imagen 1 de 2 HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: paso 6, imagen 2 de 2
    • Slide the CD drive out the side of the laptop.
Conclusión
Brian Cornet
Miembro Desde 10/21/19
316 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 510
