Introducción
Use this guide to replace a faulty battery.
There are many reasons why you may want to replace your battery. The common issues are usually low battery life, battery not holding a charge anymore, or just simply the battery is completely dead.
Before replacing any parts on your computer please refer to the troubleshooting page which may give you some solutions on how to fix your battery issues before buying a new one.
Make sure all power is fully disconnected before the rear laptop cover is removed.
Qué necesitas
Turn the laptop over so the back is facing up. Use a Phillips #0 screwdriver to remove the 11 screws from the bottom cover. Rotate the screws counter-clockwise.
Eight 5mm screws.
Three 10mm screws.
Remove the six 5mm screws securing the battery using the Phillips #0 screwdriver.
Gently disconnect the battery from the motherboard with a plastic opening tool and remove it from the device.
Charge it to 100% and continue to charge it for an additional two hours. Next, unplug the charger and use the laptop normally to completely drain the battery. Wait at least five hours and recharge the battery to 100%.
Una persona más ha completado esta guía.
Un comentario
Bonjour, please, aidez moi, mon ordinateur HP Pavilion 15 cs00051 ne démarre pas, seule le voyant du bouton d'allumage et le voyant de charge clignotant continue
