Saltar al contenido principal
HP Pavilion 13-s128nr Battery Replacement
Qué necesitas
  1. HP Pavilion 13-s128nr Battery Replacement, Back Panel: paso 1, imagen 1 de 2 HP Pavilion 13-s128nr Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Battery Replacement: paso 2, imagen 1 de 1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion 13-s128nr Battery Replacement: paso 3, imagen 2 de 2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
  4. HP Pavilion 13-s128nr Battery Replacement, Battery: paso 4, imagen 1 de 2 HP Pavilion 13-s128nr Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Lift upwards on the black tabs the purple strip is connected to.
    • Gently pull the purple strip out of its place.
  5. HP Pavilion 13-s128nr Battery Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the five screws holding the battery in place.
  6. HP Pavilion 13-s128nr Battery Replacement: paso 6, imagen 1 de 1
    • Pull the white cable connected to the motherboard out using the iFixit opening tool.
  7. HP Pavilion 13-s128nr Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery.
    • There are little snap tabs on the right side of the battery. Be sure not to break them by pulling the battery out towards the left side.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 1,121
