Introducción
If the bottom case of your device become cracked or damaged, this guide will show you how to replace it.
Qué necesitas
Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
Use Phillips #0 to remove four 9mm screws.
Use Phillips #0 to remove seven 6mm screws.
Una persona más ha completado esta guía.
