Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads. Use Phillips #0 to remove four 9mm screws.
  • Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
  • Use Phillips #0 to remove four 9mm screws.
  • Use Phillips #0 to remove seven 6mm screws.
Insertar traducción aquí
